I install 26 PV Solar Panel of 255 Watt, VOC 34 Volt, SC Current 7.3 Amp, Application Water Pump, 3phase Motor with inverter, 13 Panel use in series (02 Strings use in Parallel).
Voltage at inverter terminal are 414 VDC. When run 3 Phase motor, unloaded motor run normal till 50 Hz. When put pump load after achieving 35 Hz, load increased, and DC input voltage of inverter decreased speedily toward 300 VDC. Inverter tripped at protection under volt.
Please suggest me its problem of PV panels or Pump? All PV Panels SC current normal 7.3 Amp and VOC 34 VDC.
