I want to retrieve the level measurements from a radar distance meter using a 8051 microcontroller and a serial HART modem (Smar's HI311). I'm only interested in the measured level, I do not need to configure the distance meter at all.
How can this be done? I only learned about HART a couple of days ago and it is not as obvious as I thought it would be. Is it possible to simple send a succession of serial commands every time I need the level?
I'm the only master and there is only one HART slave (the distance meter) in the system. So far I learned that should make things a little easier for me.
Thanks,
Sytse
Thanks,
Sytse
