<p>Hi, everyone.
<p>I've got a project that sending control commands to the module (small device that moves camera pan and tilt) through serial port with C, C++, using VC++.
<p>I want to send commands like these, "A50","B85".
then the device move.
<p>I try to compile&run that open port and set the parameter the followings:
<pre>
#include <windows.h>
#include <stdio.h>
int main(int argc, char *argv[])
DCB dcb;
HANDLE hCom;
BOOL fSuccess;
char *pcCommPort = "COM2";
hCom = CreateFile( pcCommPort,
GENERIC_READ | GENERIC_WRITE,
0, // must be opened with exclusive-access
NULL, // no security attributes
OPEN_EXISTING, // must use OPEN_EXISTING
0, // not overlapped I/O
NULL // hTemplate must be NULL for comm devices
if (hCom == INVALID_HANDLE_VALUE)
// Handle the error.
printf ("CreateFile failed with error %d.\n", GetLastError());
return (1);
// Build on the current configuration, and skip setting the size
// of the input and output buffers with SetupComm.
fSuccess = GetCommState(hCom, &dcb);
if (!fSuccess)
printf ("GetCommState failed with error %d.\n", GetLastError());
return (2);
dcb.BaudRate = 9600; // set the baud rate
dcb.ByteSize = 8; // data size, xmit, and rcv
dcb.Parity = NOPARITY; // no parity bit
dcb.StopBits = ONESTOPBIT; // one stop bit
fSuccess = SetCommState(hCom, &dcb);
if (!fSuccess)
printf ("SetCommState failed with error %d.\n", GetLastError());
return (3);
printf ("Serial port %s successfully reconfigured.\n", pcCommPort);
return (0);
</pre>
<p>But I'm stuck with how to write the commands to serial port.
Does anybody can help???
Please reply.
<pre>
#include <stdio.h>
DCB dcb;
HANDLE hCom;
BOOL fSuccess;
return (1);
if (!fSuccess)
return (2);
if (!fSuccess)
return (3);
return (0);
</pre>
Please reply.
