Please need help
The SRV ON FRAME 7 was blocked on the position 30% to 45%
That means CMD and feed back are correct and when it's was command 30 feed back is 30% and CMD =30to 45 % feed back was always on 30% after 45% the feed back will be same 45%
The valve mechanical blocked on this value 30-45%
There is solution to change the cst not following trip from5% to 7-8%
Is there any other solution because from 0-30% the CMD and feed back are same and 45-100% also feed back same only 30-45% the CMD are not same to feed back
Kindly if there is solution without change the valve ? This tomporary solution !
