sb
Very interesting topic..
I have got many points from experience you shared. We do have suffered that problem twice on our machine.and alarm turbine shaft failed to break away was also received. Controlman and Salman points are exactly that were faced
Once it was due to Generator lift oil discharge pressure low, and second time it was due to Lube oil console level low switch in actuated state. in both cases Machine will not come on Turning Gear.
