the task is to find the 96% response time for a thermistor. By plotting a graph of resistance against time for that thermistor, when i find the 96% point for that graph, will that be the same time for the 96% point on the temperature-time graph.
i would have thought that if the two times were the same that was presuming a linear relationship between temperature and resistance for a given thermsitor. However from the equations that i have found, this doesn't seem to be the case? When i plot the resistance against time graph, this is exponential decay graph, is that also the same graph for the heating of a thermistor graph (temperature-time)
Any thoughts on this would be appreciated or a website that might explain the releationshiop between temperature and resistance
