O
I have an application that uses two heat exchangers to control the temperature of the medium. One heat exchanger heats up the medium if required (using black steam) and the other cools it down if required (using chilled water). Both HEX have control valves installed to control the heating / cooling.
I have the control valves configured as split range.
My question is: How can I tune the PID parameters?
