Sir,
Today I have visited ur site and find intresting Questions and their answers. I have following queries regarding the Torque Control in DC Motor.
1. What is Current Mode in the Variable Drive of DC Motor and what happen when Motor runs in Current Mode and what is effect on Armature and Field Current Mode?
2. Suppose in Cold rolling Mill three Mtors are running and Coil is Loaded and if coil gets break then what will be the Impect on Motors means at which speed motors will run and why?
3. How Tension is controlled and what are the Motor Parameters?
4. Can DC Motor can be run in Speed and Current Mode Both when Variable DC Drive is connected, If Yes How it Operates in Both Mode in terms of Armature Voltage and Current and Field Voltage and Current?
Waiting For the Early and Positive Response.
You can also mail at my following Mail ID also
[email protected]
Once Again I request you to respond as Early as Possible.
Aditya Saxena
Mumbai, India
[email protected]
Aditya Saxena
Mumbai, India
