E
Dear CSA/PV and all..
Ours is a GE Fr5 Mk6 controller GT. While the turbine was running under 10 MW load,the following alarms appeared:
1. L86TCI_ALM Compressor inlet TC disagree
2. L3VTCC_ALM Exhaust TC card fault from "S" core. "R" and "T" core OK.
On going thro the fault findings,[these diagnostic alarm come and goes] the CIF-2 value goes on and off whereas CIF-1 value is steady. This attributes to the cause of this alarm. Apart from these alarms, core<R><S>and<T> also have VSVO diagnosis alarms for "LVDT#4 RMS voltage out of limits" which is originating from <T> core. Under these existing alarms, while the operator tried to carry out "Master Reset", the turbine load started reducing and BKR got opened due to Reverse power.
How the "master Reset"could affect the load reduction in this case?Turbine started again and instructed NOT to carry out "Master Reset" unless it is most essential. We also have slot#1"VCMI"fault Diag. alarm for<S>core. (Bit error5 and VME error bit 4 being logic "1") NOT getting RESET.
Kindly advise/suggest..
Thanx...
Thanx...
