K
hello friends... i m krunal shah, i m new person of instrument maintenance. i want (1) flow rate at 8 kg/cm2 pressure, (2) differential pressure with the help of that calculated flow rate.
friends i have following data for 3T BOILER:
pipe size ID: 105.05 mm
For flow transimmiter,primary element: orifice plate
BITA ratio for orifice plate: 0.43
maximum flow range for 3T boiler: 3T/H
required pressue P1= 8 KG/CM2 T1= 169.4 C
P2= 13 KG/CM2 T2=191 C
maximum pressure P3= 15 KG/CM2 T3=198 C
(pressure and temperature data are according to steam table)
if possible then please tell the formula / equation for calculating flow rate at 8 kg/cm2 pressure and also formula for calculating differential pressure.
Thanking you.
Thanking you.
