According to the standards, pressure transmitter should be installed below the pressure tapping point for the water process line.
what if pipe line is installed on the ground level, so transmitter is installed above the tapping point? Is it possible to solve this problem with offset elevation setting? What is key reason of installing of pressure transmitter below the tapping point?
Thanks.
Thanks.
