Ampao
I have a question that may require your expertise CSA.. How can generators supplying a considerable number of loads be able to keep up with the continuous change or variation of load levels.
Its Like we consider a prime mover of a generator to be an engine of a car where the varying loads as the off road terrain. What part/device of the generator that assumes the role of the driver in a car. And how can that part/device be able to keep with the abrupt and unpredictable changes of the loads.
A realistic example would be say i have a 2KVA portable generator supplying a residential load of 1kW (resistive). Then suddenly I switch on five 100w light bulbs altogether as part of the loads in the house. Will the generator be able to provide 100% power to the light bulb right away? Or it will take sometime? or worse will it trip? Thanks in advance for you reply.
