WINCC Audit
siemens
My project having 2 server 4 clients, configure the wincc audit. If i using the customized object the value is auditing from both the server and clients side,
In another case if i using the standard objects, i.e, IO Field, i change the value in client side this action is not auditing in server. I enable the operator input msg in properties. then also it's not working.
The same object i changing from the server the value is auditing.
Please tell me where i making the mistake.
J.Sundar
