I need to find a wireless control system for the control of a multizone air handler which has dampers that mix hot and cold air for modulated temperature control. I need several zone thermostats and controller(s) with a modulated output for damper motors that will have to maintain a precise position for accurate temperature control. The damper motors need to be powerful enough to drive the dampers in a 60 ton air handler that has a 10 h.p. blower motor. This application is in an old building with lots of metal in it, plus the old steel mesh/plaster sub ceiling between the first and second floors of this two story building. I looked at the Kele site, but it doesn`t show anything with a modulating output. Anybody know where I can find this animal?
