Considering the I/O PSCDM024DCBAN, Critical Discrete OutPut Module 24Vdc, and that was setting on the SW List Parameter regarding one specific channel:
1. "Enabled" of Parameter "PulseDiagnosticTest"
2. "Enabled" of Parameter "OpenCircuitTest"
Questions:
1. What is the SW behavior when occurs a short-circuit (zero impedance <496 Ohms) at the load field of the a one channel of the PSCDM?
2. What is the SW behavior when occurs a short-circuit (zero impedance >496 Ohms and <4010 KOhms) at the load field of the a one channel of the PSCDM?
3. If occurs a short-circuit at output load the error and msg code SSC07 EC37 was been triggeded, and after solve and fix it the short-circuit in the field, if the msg code SSC07 EC37 still remain trigger, what we have to do?
4. To solve this situation, must we "reset" (Disable + Enable) of the "PulseDiagnosticTest"?
Please try clarify us this question.
Thanks in advance!
Johann Correa, Salvador-Bahia Brazil
Computacional Enginner Student
Questions:
Thanks in advance!
