Fluid Systems
Instrument and Process Equipment Symbols
This section shows some of the many instrument symbols found in different types of technical diagrams used to document instrument systems.
Line types
Note: the single backslash signifying a “discrete” or “binary” signal type has been removed from the ISA standard as of the 2009 ANSI publication. Regular pneumatic and electrical line symbols may represent either continuous or discrete states. The “triple-slash” alternative linetype for electrical symbols is also absent from the 2009 ANSI/ISA standard.
Process/Instrument line connections
Instrument bubbles
Process valve types
Valve actuator types
Valve failure mode
Liquid level measurement devices
Flow measurement devices (flowing left-to-right)
Process equipment
Functional diagram symbols
Single-line electrical diagram symbols
Fluid power diagram symbols
