E
Appreciate if someone could share the knowledge regarding this:
The 110 VDC supply to the solenoid valves are common and coming from the control room. As I understand, the voltage polarity (+ve/-ve) of the coil doesn't matter when connecting to the 110 VDC supply. However, some mentioned that there is some effect of connecting the coil with different polarity in which it may shorten the life of the coil. Is this true? If yes, any explaination or reading material is very much appreciated. Looking at the coil wires, both are RED and no polarity sign is marked as is it wasn't really important.
We experienced the coil shorted after one day in operation. We are in process of determining the root cause.
TQ
TQ
