Most PLC's read analog values via a 12-bit A/D then post the results into a 16 bit holding register. Somehow they expand the 12 bit value to use all 16 bits of the holding register. How is this done? How is the sign bit represented?
P | endianness for 32 bit data | Modbus | 4 | |
K | Modbus Library for C# That Can Use 32-bit Register Addresses? | Modbus | 3 | |
D | Forcing a Bit on a micro 1400 | Programmable Logic Controller - PLC | 1 | |
P | How to read 64 bit value | General Communications Chat | 0 | |
M | Start/stop/idle bit value in RTU frame | General Communications Chat | 4 |
