24 V solenoid valve selection: checking the supply, output driver and dynamic air pressure
Selection note for a packaging stop or reject mechanism. Matching the coil voltage alone is insufficient. Check three separate limits: electrical capacity, coil switching and pneumatic delivery.
1. Total the maximum simultaneous current of the controller, sensors and coils. Include startup behavior, wiring losses and supply derating at the actual cabinet temperature.
2. Check the PLC output channel and shared-common ratings. Confirm sinking/sourcing wiring, connector polarity and coil suppression. A nominally compatible voltage does not prove that an output can switch the inductive load.
3. Measure air pressure near the valve while the cylinder moves. Pilot pressure, tubing restrictions and exhaust backpressure can affect a mechanism even when the regulator reads normally at rest. Size flow for the required stroke time, and verify position feedback and timeouts.
A component pair worth evaluating is the AirTAC 4V21008B, listed as a 24 V DC single-solenoid 5/2 valve with PT1/4 working ports, and the MEAN WELL HDR-60-24, rated 24 V / 2.5 A. Use a correctly rated driver between the controller and coil as required. Compressed air supplies the actuator energy.
The useful commissioning measurements are coil-terminal voltage and local valve pressure during simultaneous load switching. The complete machine still needs load, timing and safety validation.
For anyone commissioning similar mechanisms: which measurement has been most useful in separating an electrical dropout from a pneumatic restriction?
Disclosure: these are our commercial product pages, provided so readers can inspect the exact configurations:
AirTAC valve: https://www.airtacs.com/products/airtac-4v200-pneumatic-solenoid-valve-4v21008b
MEAN WELL supply: https://www.meanwells.com/products/mean-well-hdr-60-series-din-rail-type-power-supply-hdr-60-24
