E
LSL = Lower Sensor Limit
LRV = Lower Range Value
LSL of 3051TG on HART = 0 Kg/Cm2
LRV is configured at -1 Kg/Cm2
On data sheet of 3051 TG range is given from -1 Kg/Cm2 to 2 Kg/Cm2. Why HART is reading LSL 0 Kg/cm2? It is not possible to configure transmitter outside range of LSL and USL, then how this transmitter is calibrated below LSL. Also on datasheet of 3051TG it is mentioned that lower range varies with atmospheric pressure. what does this exactly mean? I know that value of maximum vacuum can not be less than atmospheric pressure.
You can reply me on my email address
[email protected]
Thanks for attention
[email protected]
