I just got a hand on this interesting GEI100513 HMI TIME SYNCHRONIZATION Manual:Hello Anees,
The thing that you can do for your information, is to have read on these threads regarding incorrect time/date inMark HMI/CIMPLICITY:
https://control.com/forums/threads/...el-date-and-time-using-hmi-not-lt-i-gt.25552/
https://control.com/forums/threads/mk-5-hmi-time-display-problem.25450/
Thats what i can suggest till now , without be able to have a read on Mark5 HMI/CIMPLICITY manual.
I am sure it can help for resolving this issue.
ControlsGuy25.
Hello ALL?Dear all , thank you for you support
i try editing timesync.dat but nothing is changing ....
dear #CSA this CPU which we are using is HP compact dc 7700 . this is same using in the most plants in mark v hmi as per my knowledge . and there no communication problem with markV and hmi . i tried timesync , aslo NTP .
BUT NOTHING IS CHANGING .
AND NOW I AM STRACK WITH THIS .
TIMESYNC.BAK IS THERE AND TIMESYNC.DAT IS THIS BOTH ARE SAME ?
TIMESYNC.BAK
; Timesync.dat file generated by TCICPL on 13:03:26 07-18-2020
TIMESYNC LOWRES
LOCAL_TIMESET ENABLED
TIME_LOAD LOCAL
TIMESYNC.DAT
; Timesync.dat file generated by TCICPL on 18:11:31 07-18-2020
TIMESYNC LOWRES
LOCAL_TIMESET DISABLED
TIME_LOAD LOCAL
IS THERE ANYING WRONG ??
CAN YOU ANY ONE HELP ME WITH THIS ?
View attachment 412View attachment 413View attachment 414View attachment 412View attachment 413View attachment 414View attachment 412View attachment 412View attachment 413View attachment 414
Yes.... i tried with the documents you give... its also not worrking.Hello ALL?
Anees,
Did youy have look on GE doc that I shared?
I am not at your site but this document, should be an help/support for getting that Time synchronysation configured .
Thanks for your feedback,
ControlsGuy25.
