I have a question regarding the 5 way manifold.
In my application, a multivariable transmitter will be installed on the 5-way manifold which will be mounted into a flow meter.
Liquid samples will be taken from the 5-way manifold drain point regularly and I would to know if there will be a risk that the multivariable transmitter could be damaged due to process fluid going into the multivariable transmitter while collecting samples through the drain port ?
Best Regards,
Best Regards,
