If you're still having problems after downloading and using the Modbus Slave application instead of the Modbus Poll application, please post your complete code for your ESP32.Modbus Poll is a Modbus master simulator. If your ESP32 is indeed a master, then this won't work, as a Modbus master cannot communicate to another Modbus master. You would need to use the Modbus slave simulator instead (https://www.modbustools.com/modbus_slave.html).
There was no code in your post.this is the complete code for the esp32
| Thread starter | Similar threads | Forum | Replies | Date |
Checksum error, Insufficient bytes recieved, Timeout - Modbus Poll | Modbus | 21 | |
| G | Auma Actuators AC 01.2 which are failing to bootup with WD-Timeout error | Control Valves | 36 | |
Modbus timeout error | Modbus | 1 | |
| I | Communication problems , modbus timeout error | Modbus | 3 | |
| M | FX5 PLC Modbus RTU Slave Timeout Error | Modbus | 6 |
