Rotor earth fault for Diesel generators
What are the methods for detecting earth faults in rotor windings without using slip rings? This is for diesel generators with a capacity of 3 to 5 MVA.
Is it possible to use instruments like Brush Prismic R10 Rotor earth fault monitor for these generators (3 to 5MVA). What are the disadvantages of using this?
Does the current injection principle for detecting ground faults require slip rings?
Is rotor earth fault detection necessary for generators in this capacity range?
