Gearbox document
Dear all,
As part of a technical assistance to address an issue in the gearbox (side pump) of the MS3002 turbo pump unit (DVDS 20X20X28 pump), we would like to provide the following information:
-MS3002 Serial Number: 244/371
-Pump (DVDS20x20x28) Serial Number : 741N0610.2
The technical specifications of the gearbox are as follows:
Name: R2 Speed Gearbox
Manufacturer: IGE/Byron Jackson
Type and/or model: S-238-AZ
Serial number: 245477
Gear ratio: 6519/2725
Power: 11600 hp
Number of pinion teeth: 51
Number of driven gear teeth: 122
Number of stages: 2
Gear Type: Helicoidal
We kindly request the following documents:
1. Mechanical Maintenance Procedures
2. Gearbox Overhaul Report and Quality Plan
3. Gearbox Removal/Assembly Procedures and Gear Clearance Guidelines.
Best Regards.
Have you contacted the manufacturer?
Given that this is a controls forum, it is not very likely that the forum's readership will have access to mechanical maintenance procedures, so don't get your hopes up too high for a response.
