Hi everyone,
Hoping someone here has dealt with high-static industrial environments and HP workstation grounding quirks. At Core Blast Solutions, we manufacture automated pressure blasting rigs. I’m currently running a custom CLI diagnostic and logging script on an HP ZBook Fury 15 G8 (Win 10 Pro) connected to our cabinet PLC over Modbus RTU (RS-485, 2-wire, 115200 baud, 8N1).
Sensors being polled via CLI (50ms intervals):
The exact second I plug the HP 150W Smart AC Adapter (3-prong barrel jack) into the shop floor receptacle near the control panel, my CLI terminal starts throwing Modbus CRC checksum mismatches and garbage hex framing errors (0xFF, 0x00)—but ONLY when dry abrasive media is actively flowing through the blast hose and boron carbide nozzle. If we run "air only" (no abrasive media flowing), the serial comms remain stable even with the HP charger plugged in.
My Hypothesis: High-velocity dry abrasive media (especially garnet and aluminium oxide) generates massive triboelectric static voltage along the blast hose. Even though our blast pot and tungsten carbide/boron carbide nozzle holders are bonded to earth ground with antistatic whip cables, I suspect the HP Smart AC brick’s internal EMI Y-capacitor is coupling the building's 230V AC protective earth directly to the ZBook's USB/Serial 0V reference. That turns my RS-485 cable shield and signal ground into a return path for ESD spikes.
Questions for the forum:
Core Blast solutions
- Hopper load cells (tracking real-time steel grit / aluminium oxide consumption rate)
- Air-line moisture separator dew-point sensor
- Nozzle throat pressure transducer (monitoring 80–100 PSI blast pressure)
- Deadman handle safety interlock status
- Has anyone measured the chassis-to-earth leakage current on HP ZBook Smart AC power bricks in high-ESD environments?
- Will placing a DIN-rail 2.5kV galvanically isolated RS-485 repeater (like a Moxa TCC-100I or Waveshare industrial isolator) between the PLC and the HP laptop completely break this ground loop?
- Should I also lift the RS-485 cable shield at the laptop end and terminate the cabinet end through a 100nF capacitor to block 50Hz ground currents while still shunting high-frequency static?
