I'm new to the MK V system. My control system of origin is the Wonderware HMI used on naval vessels, so my verbiage might be wrong. However, there's something I noticed very similar and frustrating about both systems. They have those small screw in wire holders on the FTM/"Din Rail" or TCEA Cards. I wanted to see if there was a fast connection cable that you could use to connect a simulator into the plug/wire holder without loosening the screw. Something that connects to the top of the tension screw. Is anyone aware of such a convenient device?
Before anybody says to just loosen it, the reason I am asking is because technicians I have seen are prone to stripping the screws on these boards.
