We need start a new system in our power plant (water injection system) on a ms6001b turbine, which is running on gas fuel.
Our control system is <I> mkv tmr.
I need to add a new analogics signal (4 - 20 mA) in the csp. for example an input pwq (water injection pressure from skid in the water plant) and an output wsrout (water injection control valve actuator).
All I need to know is the procedure to achieve that.
In other hand I want to know if it is possible add in demand display an input or output analogic with its units in miliamper.
thank you in advance.
