AEG Transinaut
Всем привет!
Somebody know about AEG transinaut. Please if somebody have information send me mail. Out power plant stay and we do not have anything, how can I connect to these controller and just change one signal, if somebody have how can I do, please let me now iT??
Всем привет!
Hi All
Aibol
It looks like AEG got representative enginnering company ( called dialog teknika) in Russia in case you are from there.
Here is the link :
http://www.diateh.ru/english/engl_aeg.htm
Also can you explain better how is situation, as we do not know if its old/ new installation, also we do not know what kind of documents you have from Vendors /Oem ...
AEG documentation seems to be "rare" on the web.
Do you have any documentation at least from supplier of these equipments?
Please try to expalin better the plant situation.
Since there is too much unknow, i just can share with you the company link .
Hope this can be an help,
Hope this can help,
Controls guy25
Hi All
Aibol
Here is the link :
Hope this can help,
Controls guy25
Good day, everyone!
Firstly thank you for information about russian company today i will try to connect with them, maybe they can give some information!
Secondly we have 3 emergency diesel generators in our PP, two of that on normal operation (Power 1,5MW each) and one in the commissioning phase(power 3MW) every week we check two generators in test mode, it means generators one by one start and gain power almost 500kW and stands until the operators turn off, last time one of generator always turned off by protection reverse power, and we try to replace transinaut from generator which did not used, After that generator doing mystically thinks and we returned to the place! We think the controller lost logic in memory.
Hello Aibol!
The AEG-Transinaut was developed by Mr.Johnsen (http://elnost.de/kontakt.htm). Also the most Application has done by him or his Partner.
If you Replace Parts form the Transinaut you must also replace the Firmware-Eprom and the Program EEprom -> otherwise you Generator has the wrong Softwareapplication. If the Memory is lost nothing would work.
If the Problem is “only” Reverse Power you should check also the Engine -> mostly it’s a Problem of the engine or the controlunit for speed.
Hello Aibol!
Thank you, I already wrote them email but did not received answer! I don’t have any contact information about this company! Please if somebody knows something about company elnost or controllers “transinaut” contact with me, thank you!
Good day, everyone!
Good day Aibol,
Is there possibility for you, to connect laptop with Transinaut Device, and get some trends or historian/trip log report ??
Can you describe us, what kind of "mystical" things that generator is doing?
We may be able to assist you, as much as we can from this excellent forum!
Conntrolsguy25.
Good day Aibol,
Conntrolsguy25.
Good day!
No it is not possible because we don’t have software for connecting!
Software for Transinaut is "TRAPMAC" - you could only upload the SW-Application to the Controlboard -> there was never a function for onlinediagnostic
Hello,
We have Transinaut SRC controller for EDG (emergency diesel generator) at one of our Chevron facility.
We cannot support this PLC and we plan to replace it with a similar one or update the SW, now we have contacted the supplier AEG, they are processing our request, but they have been reorganized and they do not know if they have the right specialists who can help us .
I know that Transinaut SRC was developed by ELNOST company, but open sources say that this company closed in 2018.
I'd like to ask for your help here, can someone help with providing SW TRAPMAC so we can read the controller logic. We are also currently considering a replacement for an Allen Bradley controller.
I will appreciate any answer.
What’s your problem with the transinau an do you have a projectnumber?
You can’t download the application from Transinaut to PLC only upload.
Do you now who commissioned the plant – Mr. Johnsen or Mr. Friedrich?
regards
Georg Reikl
regards
Georg Reikl
Dear Georg,
Thanks for your feedback. I send you an email through outlook, commission plant was done by Mr. Johnsen.
