V
We have Frame V gas turbine and we are facing problem that AHOP doesn't developing pressure beyond 50 Kg/Cm2 and our normal requirement is 90-100 Kg/Cm.
We have carried out the following activities:
1) AHOP Pump overhauling done and installed.
2) Hydraulic oil circuit flushing carried out.
3) Hydraulic manifold components like PRV & Check valve dismantled and cleaned and installed back.
4) Hydraulic manifold cleaning also done.
After above activities still we getting only 50 Kg/cm2.
Pls suggest any idea to solve this problem.
We can start gas turbine with 50 Kg/CM2 hydraulic oil pressure?
Matter most urgent.
Matter most urgent.
