But the requirement is for two-level. I'm afraid I cannot change that.You using a 2 levels inverter and Mathwork advising to use 3 levels inverter
OkayWhat I have implemented is not exactly from that reference..... It's a bit different.
Yes, I'm confident about that. It's just difference between predicted and reference current. I'll have a variable and store the least calculated error. If any further states give lesser error, then that will be the new optimum.Are you sure with the cost "minimization " function implementation ...
Also what about current estimation/prediction ISP1 ....
Looks like something is missed in the application code...
Predictive Control for Drives and Power Converters - J.Rodriguez and Patricio CortesHi 2000
What document are you referencing?
let me see if I have that....Predictive Control for Drives and Power Converters - J.Rodriguez and Patricio Cortes
Sorry for the late reply, I ain't able to find the solution.Did you make any progress?
Sorry for the late reply. I didn't find any solution to that.Any update ...
Thx for replying..
Yes, if you plot alpha vs beta. With some ripples. I'm getting that right....what does your Stator flux look like in the alpha and beta it should be a circle?
