I have a 4-20mA non-loop powered E+H promass 83F40-AD2SAABAAFAS mass flowmeter. It is a 4 wire instrument. 2 wire to power the circuit boards with a 24VDC power source. Another 2 wire for the 4-20mA passive loop. The unit is ATEX II 2GD EEx d(ia) IIC approved.
Here is where I am losing it:
If it is EEx d - this means it is an ex-proof enclosure - so why do I need an IS barrier?
Why is there another rating of EEx d (ia) - which is IS protection class?
If I were to play it safe and put in an IS barrier for the 4-20mA passive loop. What about the 24VDC which is required to power up the rest of the circuit board. Do I need to have an IS power supply too? e.g. from MTL.
Or should I just power the entire unit using non-IS circuit i.e. do away with the IS barriers on the 4-20mA passive loop and power the rest of the circuit board using a normal 24VDC power supply.
