Respected sirs,
In our CPP there are 6 gas turbine generators ( frame 9e ) FOR EACH GT WE HAVE TWO BATTERY CHARGER ( 2*100% ) TO FEED EMERGENCY SUPPLY TO GT AUXILIARIES LIKE MARK-6 , EX2100 , PROTECTION PANEL , EMERGENCY LIGHTINGS, MCC INCOMING BREAKER CONTROL CIRCUIT ,VERSAMAX ETC.
My first question is "what will happen if BOTH BATTERY CHARGER FAILS when gas turbine generator running normal?" BATTERIES ( 220 AH,125 VDC ) ARE ALSO CONNECTED TO 125 VDC BUS TO FEED SUPPLY IN THE CASE OF BATTERY CHARGER FAILURE IF THERE IS TURBINE SHUTDOWN IN EVENT OF BOTH BATTERY CHARGER FALURE , THEN WHAT IS THE LOGIC BEHIND GIVING SHUTDOWN COMMAND TO GT. WHAT WILL HAPPEN IF ONLY ONE BATTERY CHARGER FAILS?
MY SECOND QUESTION IS IN THE EVENT OF AC SUPPLY FAILURE TO BATTERY CHARGER ONE OUR GT TRIPPED , DUE TO MEGAWATT TRANSDUCER SIGNAL. I DON'T KNOW WHAT WAS THE SIGNAL BUT I WANT TO WHAT IS CONNECTION BETWEEN BATTERY CHARGER AC SUPPLY FAILURE & MEGAWATT TRANSDUCER ?
IF ANYBODY AWARE OF THIS REPLY ME.
