Hi All
This is my first post on this forum so please correct me on any formal things.
I am working with Renuelectronics gateway GWY-00-B which translates modbus RTU from PLC to the modbus ASCII for the particle counter.
Sadly this converter is not working as it should.
Would you be so kind and:
Regards Hewking
- advise me on the tools needed to diagnose/ troubleshoot the gateway - is Modsim simulator and modbus client good tool to do that - so i can in theory trigger a value in modbus simulator and see if the gateway sends it properly at the other end?
- Are there any protocol analysers to analyse the modbus RTU, modbus ascii or modbus RTU communication at the frame level? would it require hardware like oscilloscope or is software solution possible as well?
- Trying to broaden the question - i try to learn more about industrial network - are there any monitoring tools/resources to help me to become master of modbus, industrial ethernet, RS-485, RS-232, Mqtt etc ?
Regards Hewking
