i have a Citect OPC DA where i can not connect it with another application.
While i am able to connect with OPC clients (like Matrikon's etc) when i try to connect with this application it says "Lost connection".
The application is installed in the same machine with the OPC server so it's probably not a DCOM issue. The user that i am running the other application is the OPC user.
The same application (with the same configuration) it is working on another OPC DA that i tried.
So i do not know if the issue is from the OPC or from the application.
Any ideas?
Any ideas?
