I must make a communication of a sort of data, using the Ethernet.
And for that I need to know the protocols and other methods of communication that GE PLC supports.
Up to now, I have Ethernet Global Data (private), SRTP (no Mitsubishi compatibility) and Modbus/TCP (which both of them supports).
But I do like to know if GE PLC support a buffered communication using only direct message (without a defined protocol)? Someone has used direct communication like this?
Thank you.
Thank you.
