Hello I try to put a normal profibus-DP network between Yokogawa ALP111(as a master) and a Siemens ET200M IM153-1(SLAVE) with a 32xDI module attached(6ES7-321-1BL00-0AA0).
We already use the SyCon obtained from Yokogawa(SyCon-PM/YOKO or SyCon-DNYOKO), and we have the License or Keycode LFS2542 for Profibus Comm. on Yokogawa CS3000 R3.08. Also we import to SyCon the ".GSD" file for "ET200M IM153-1" from Siemens.
We configure the SyCon and generate the ".dbm" file and imported to the module ALP111 properties on System View.
We fill the %%WWxxxx table on System View for the module. We download and undpate the controller, and we get a Comm. failure "CA91" on the CS3000 and a flashing BF red led on the ET200M.
We check almost everything with out results.
What do you suggest to check?
Thanks.
Jesus Carrero Blanco
Thanks.
