Connecting Raspberry Pi to DSI Display for HMI Projects – Practical Tips
Hello everyone,
I am working on a few compact HMI (Human Machine Interface) prototypes using Raspberry Pi and was looking into using DSI displays instead of HDMI for better integration and performance.
DSI (Display Serial Interface) offers several advantages in embedded HMI applications — lower power consumption, cleaner wiring, higher frame rates, and more direct integration with the Raspberry Pi’s GPU. However, getting it to work reliably requires proper hardware connection and configuration.
Here are the main steps I followed:
Hardware Connection
  • Use the dedicated DSI port on the Raspberry Pi (labeled “DISPLAY”).
  • Connect using a compatible 15-pin or 22-pin FFC cable.
  • Pay attention to cable orientation and locking tabs.
  • For touch-enabled displays, ensure any additional I2C or USB touch connections are properly handled.
Software Configuration
  • Enable DSI interface via raspi-config.
  • Add the correct device tree overlay in config.txt.
  • Configure resolution using hdmi_cvt parameters.
  • Install and calibrate touch drivers if using capacitive touch.
I ran into some common issues like black screen on boot, wrong resolution, and touch not responding — mostly solved by correct overlay and sufficient power supply.
I would appreciate your experience on:
  • Recommended DSI display models for reliable 24/7 operation?
  • Best practices for stable touch integration?
  • Any major pitfalls when moving from HDMI to DSI?
For a detailed step-by-step guide that helped me a lot, here is a good reference: How to Connect Raspberry Pi to a DSI Display
Looking forward to your insights. Thanks!
