Hello Friends,
My plant has been having issues of ratchet trouble on one of our turbines(GE Nuovo Pignone MS5001 Frame V).
This issue started when the unit tripped,it was later observed that it could not ratchet,the cause was channeled to the overrunning clutch as the torque converter jaw clutch could not turn.Damaged overrunning clutch was changed and unit ratcheting sequence was ok and turbine started.
It was observed that on consequent turbine trips,unit could not ratchet unless damaged overrunning was changed,which was not a good operation and we decided to change the torque converter as our root cause analysis boiled down to it.
Torque converter successfully installed and ratcheting sequence was fine for about four months,then the initial problem surfaced again.
Please guys what could be the root cause and the possible solution to end this miserable mode of operation.
Thank you.
Thank you.
