W
1) It is my understanding that if a control valve is installed downstream of a centrifugal
pump, then the following will occur for minimum flow: namely, the ACTUAL inlet pressure will be maximum and the ACTUAL pressure drop across the control valve will be maximum.
Similarily, the following would be true at maximum flow: namely, the ACTUAL inlet pressure will be minimum and the ACTUAL pressure drop across the control valve will be minimum.
In other words, for increasing load (flow), the ACTUAL pressure drop across the valve is
decreasing.
Question A:
Are the statements in (1) above correct?
Question B:
Will someone please explain to me why, in some situations, the pressure drop across a control valve would INCREASE with INCREASING load?? What are these situations?
Question C:
When a process engineer fills in my valve spec sheet with the MAX deltaP occurring at MAX flow
and the MIN deltaP occurring at MIN flow, how do I determine if this is the actual case or if
indeed this is not correct and in actual fact the MAX deltaP occurs at MIN flow and the MIN
deltaP occurring at MAX flow ????
Will some expert please please enlighten me. Thanking you profusely in anticipation.
decreasing.
Question A:
Question B:
Question C:
