CSA,
Another way to view this is by considering constant real power. At 1.0 PF the current required to transmit the power is lower than current required to transmit the same power by use of P=VI x p.f. Hence the lower the PF the higher the current needed for constant power.
According to Lenz's law, the current in the stator creates the electric torque which opposes the mechanical torque produced from the turbines. The higher the current, the higher the electrical torque hence more mechanical torque is required to generate the same power at a lower power factor.
Solomon
Solomon
