We have three gensets operated in parallel; one of them 11 KV, has a neutral earthed through resistance. The other two are 400 v connected to delta transformer 0.4KV delta / 11KV star, this star is earthed direct. The 11 KV of those transformers and the first genset are connected to one bus bar, which is connected also to a zigzag transformer with neutral earthed. when the genset 11KV is the only one on the bus, without connecting the Z transformer and the 400 v genset, the neutral ct equal zero.
In case of connecting either the Z transformer or the 400 v genset to the bus with 11 KV genset the neutral CT equal 27AMP measured on 11kv genset, and 12 AMP measured on Z transformer neutral wire, and 15 AMP measured on 400 volt transformer neutral wire. All currents have 148 HZ. please advise is this problem is harmonics or earthing problem?
