Hello everyone,
I'm developing an ESP32-based monitoring and control board that is moving from prototype quantities into a small production run.
The prototype boards have been working well, but during assembly and testing I'm seeing a few boards that occasionally fail to boot or show unstable behavior until they are power-cycled. The issue is not consistent, which makes troubleshooting difficult.
Current design includes:
The next revision will likely be manufactured through PCBWay, and I'm also reviewing panelization options.
The final product will connect to external sensors and power sources through wiring harnesses.
- ESP32-WROOM module
- Multiple I2C sensors
- RS-485 communication
- External power input
- Custom 4-layer PCB
- What are the most common PCB-related issues that only appear during production rather than prototyping?
- Have you encountered grounding or power integrity problems that caused intermittent ESP32 startup failures?
- Are there specific test points or diagnostics you recommend adding before the next revision?
- How much margin do you typically leave around power supply and RF sections?
- Are there panelization practices that help reduce handling or assembly issues?
- Have you seen breakaway tabs or V-scoring create reliability problems near sensitive circuitry?
- How much board-edge clearance do you typically leave around antennas and connectors?
- What connector families have proven most reliable for ESP32-based products?
- Do you prefer separate connectors for power and signals, or combined harnesses?
- Have connector-related failures become a significant issue in field deployments?
- Any recommendations regarding strain relief or harness routing?
