Hi all,
I've a situation where the FLow Computer is calculating Gross and Std Volume Flowrate by using metric units (i.e. base T = 15 degree C and P = atm.)
If the customer need the measurement to be based on imperial unit. Can we just use the same Flow Computer setting by setting the base T to 15.556 which is eq. to 60 F.
Plus what if the densitometer is using metric but feeding a imperial flow computer.
Thanks in advance,
Thanks in advance,
