Gas Turbine Ge FA6.03
20200904_113142.jpg Hello everyone and thank you if you help me.I want to know everything about this program.CONTROL DISPLAYS,
,Startup Control Display,
DLN Control Display,
,Gas Fuel System ,
DLN Operation Modes ,
Inlet Bleed Heat,
Liquid Fuel System,
FSR Control Display, Gen/Exciter Control, IGV Control Displa
Lube Oil Display,Motors Control Display,
Turbine Compartment Vent Fans,
Load Compartment Vent Fans,
Distillate Fuel Forwarding Pumps,
Cooling Water Fans and Motors,
Synchro Display
Air Filter
Off-Line Washing
On-Line Washing
MONITOR DISPLAYS
Bearing Temperature
Exhaust Temperatures
Generator Temperatures
Seismic Vibration
What does this mean ? Do you want to know about all the included subjects? This would be a 10 day 80 hour training course which would get you to the point of starting to learn. Don't you have any manuals and drawings for your equipment that you could at least start with ?
View attachment 515 Hello everyone and thank you if you help me.I want to know everything about this program.CONTROL DISPLAYS,
,Gas Fuel System ,
Inlet Bleed Heat,
Liquid Fuel System,
Synchro Display
Air Filter
Off-Line Washing
On-Line Washing
MONITOR DISPLAYS
Bearing Temperature
Seismic Vibration
Hello ALL,
Well there is lot of things to read and learn from appropiated and dedicated operations & Maintenance Manuals for this OEM.
Would you tell us the type of unit installed ?
Do you have any OEM manuals available ,...did you even have read one of this system/subssystem technicals manuals...
ControlsGuy25.
If the roads are closed because of the crown, what advice would you give my friend? I think it's a good person help me and to send all information to me and i will read
As it is GE frame 6FA i suggest you to contact GE belfort (GEEPE ), otherwise EPC contractor ( you said that chinese built the plant is that HARBIN power ?? ) for giving you the Operations & Maintenance manuals and a correct & good training .
We do not know about contract service agreement that you have with them ...
Also it would be good for you to get some courses at any Learning center specialised on this Type of frame.
Belfort got a training center , why did you not get that training for customer ?? Again we do not know the contract agreements that you got for this power station with your "Vendor /supplier/EPC ".
One good thing is to learn by yourself but, you will always need a trained personnel to guide you and give you highlitning points on that systems operations & maintenance.
ControlsGuy25.
Looks like your power plant is :
Gardabani Combined Cycle Power Plant Project
And Calik energy is the EPC ,
oh ok Chinese are EPC for the second phase of this project...Tianchen Engineering Corporation (TCC)
So better to contact them for gettting these informations ...
Controls Guy25.
My friend, We know at this time it is difficult to travel.
So if you are urged to learn, you can start by reading the documents on the web....
Training and learning is a tough task to achieve..
I am surprised that your vendor did not give you manuals and instructions for getting your staff trained...
That's all I can add, I know couple of trainer engineer bbut they all retired at this time.
Controls guy25.
если вы знаете, что у кого-то есть инструкция, я могу заплатить.Thanks for the feedback and help
Your are welcome !
Also , there should be surely somebody in Belfort, who can support you .
We know with this pandemic that travel are restricted but there is emails/visioconference and other digital supports can help customer to get their queries satisfied by Supplier.
In this case i again do not know the contracts agreement with GEEPE & TCC...
I strongly advise you to get in touch with one of their representative.
Actually I am from Belfort, I know very well GEEPE and how they works.
I may can give you some contacts , let me check with them and then i come back to you.
For example there is a department/service who is dedicated for Operations & Maintenance manuals.
The thing is to get the contact of one of the contact (engineer, technician, manager..)
Definitely, You should /must get some contacts in GEEPE/TCCcan you confirm??
What GEEPE/TCC told you about these questions..,?
ControlsGuy25.
Thank you so much for helping me and I look forward to your recommendation
Ok i will try to support you.
But you didnt answer to my questions ...
Can you clarify what GEEPE /TCC said about your queries?
You are lucky i got one good file for learning on GE FRAME 6FA....
We can exchange emails then i can forward it to you ...
Controls guy25.
