gas turbine that is only used at peak times was working ok but then failed to light, two burner cans removed and ignitors seen sparking. interconnecting burner tubes are ok. Tried adjusting fuel for leaner running, richer running no success. Atomising air pressure ok, nozzles ok. Any advice on what else to check appreciated...
