HI
recently one of our Frame6 machine after Fuel nozzle replacement and 1 st nozzle replacement spread is going high on Baseload SP1 at 62degC.
the replaced fuel nozzles are brand new GE nozzles.
So we suspected of Bleed valve Passing and we took the temperatures of Bleed valve upstream and down stream of all GTs for comparision. this particular GT is showing 55degC and 88 degC where as the other GT is showing 130deg C and 142deg C. we also found water driping from flexible joint after the bleed valve in this particular GT.
Can some help us in
1. What could be the reason for High spread?
2. Why this particular GT is showing such a low temperature at Bleed Valve upstream and Down Stream?
3. What could be the reason for water dripping?
Regarding water dripping, due to slight passing of Bleed valve, due to nozzle effect is condensate forming near the valve?
Can some help us in
