Dears;
would you please let me know what is the criteria to calculate the performance (formula). I need this because the following are frequently happened
1- when the lab sampler needs to take oil sample for oil check routine, he opened the lube oil tank cover whereas the accumulated vapor released and then the smoke detector activate which lead the CO2 dumping resulting the gas turbine to trip. All this located inside Accessory compartment.
2- leakage
2- leakage
