Hi Guys,
After a Major outage in one of our GE 9e units we are experiencing heavy white mist oil, when running in base load.
I sometimes appears after 30 min and sometimes after one hour. If the unit is held at 60MW for about an 30 min before going to base load, the heavy mist doesn't appear. We noticed the negative pressure in the L.O tank turns to positive shortly after starting the unit, causing the NRV bypassing the oil mist eliminator to open.
During the outage a refurbished shaft was installed, and house alignment was performed.
Oil samples were taken and the oil is free of water, and with good qualities. (the oil was changed 1.5 years ago).
The oil temp at the bearing drain lines is between 90-100 deg. Celsius. While the outside drain line is at around 70 deg. Celsius.
The mist looks like white smoke, smells like burnt oil and leaves no signs of oil on the surface close to the unit.
Has anyone experienced similar symptoms? overheating of lube oil? excess air in the lube oil return lines?
Any other ideas?
Thank you very much!
Any other ideas?
