I recently did this by uncoupling the motor from the load, disconnecting the shunt field, set the armature current limit at zero to begin with, for safety then after asking for about 5% of speed I increased the current limit until the motor began to turn. Noted the direction. Re-connected the shunt field and ran it again with the presumption that if it now turned the other way then the series field was hooked up the wrong way. (The motor went in the correct direction when I got onsite and their shunt field current was not too weak but they pulled excessive armature Amps.)
I would like to know if there is a method to check this -safely- without uncoupling the motor.
